Question CPU AND GPU USAGE QUITE LOW (mainly gpu)
Jan 29, 2020
20
Hey guys, so i have a bit of an outdated gaming pc (i3-6100 and a geforce 1050ti, 2x 4GB RAM). I dont really know alot about PC's but my fps is way lower than what its supposed to be and it has been like that for a while. I ran malwarebytes and deleted 9 PUP's. But no help there. My gpu usage is 35% in CSGO and about 50% in other games which is quite low. I know csgo is a cpu based game but i see people with the same specs get atleast 180 fps on 1920x1080 while i play with ~120 on a 1280x1024. When i change the settings to high/medium/low there is no.fps difference. Anyone that can help me out ? I changed my nividia power settings to high already, didn't work. (Btw i see some.people with the same GPU get 90% in csgo?)
ALSO! My cpu usage in csgo is about 65-75, and i'd like that to be a bit higher as well, any ideas on how to?
and what the individual core usage?
ram usage?
full system spec? include make and model of the psu
Ram usage is almost 6k
Full spec:
INTEL CORE i3-6100
Gigabyte GA-H110M-S2H (motherboard
MSI GEFORCE GTX 1050 TI 4G (gpu)
seagate hdd 1tb
Kingston hyperX fury HX421C14FB (2x 4GB ram)
Corsair VS450(80plus) -> power supply
Also, someone recommended me to reset my windows? idk if that should help tho
Really appreciate you putting your time and effort into this
Ram usage is almost 6k and as for the individual cores, its around 65-75% jumping between all cores
Full spec:
INTEL CORE i3-6100
seagate hdd 1tb
Someone told me resetting(?) Windows might be a good idea but idk if that is true or not
For some reason all my replies got deleted? so all the lovely people who tried to help me i'm sorry but here we go again:
Hey guys, so i have a bit of an outdated gaming pc (i3-6100 and a geforce 1050ti, 2x 4GB RAM). I dont really know alot about PC's but my fps is way lower than what its supposed to be and it has been like that for a while. I ran malwarebytes and deleted 9 PUP's. But no help there. My gpu usage is 35% in CSGO and about 50% in other games which is quite low. I know csgo is a cpu based game but i see people with the same specs get atleast 180 fps on 1920x1080 while i play with ~120 on a 1280x1024. When i change the settings to high/medium/low there is no.fps difference. Anyone that can help me out ? I changed my nividia power settings to high already, didn't work. (Btw i see some.people with the same GPU get 90% in csgo?). Im using that resolution because it gives an advantage in all other games i use 1920x1080, im using a 144hz monitor so i'd like to get atleast 144 fps. And no i dont have v sync on or any fps limiters
Full spec:
INTEL CORE i3-6100
seagate hdd 1tb
So i've just done some more tests and on other games that i've tried my GPU and CPU usage is 90% or more, so its only CS:GO thats having low performance
