Audio crackles briefly every few seconds in music or in game, frequency seems to vary a bit depending on the output and audio settings. Windows system sounds also crackle, and more so than other audio sources, basically continuously while they play.
The system on which the issue occurs:
motherboard: gigabyte aorus x570 pro wifi ITX
cpu: amd ryzen 5800X
gpu: k2fa RTX 3070
ram: 32GB (2 xc 16GB) DDR4 corsair CL16 RAM (overclocked)
psu: Lian Li SP750 80 gold SFX
Outputs I've tried:
3.5mm jack from motherboard and case
HDMI
bluetooth
razer headphones using usb dongle
Things I've already tried:
Changing audio quality settings
Disabling all audio enhancements
Disabling exclusive mode
Disabling all other sound devices
Making sure spatial audio is off in windows sound settings
Turning off HD audio controller in BIOS
Using High performance power plan
Uninstalling razer synapse and thx audio
Using recommended realtek audio driver version for mobo (weirdly there's two recommended and I've tried both https://www.gigabyte.com/Motherboard/X570-AORUS-ELITE-rev-10/support#support-dl-driver)
Using Microsoft HD audio driver instead of realtek by selecting 'update driver' on the realtek one in device manager and pointing it at the microsoft one
Installed all windows updates (windows 10 22h2)
Any idea what could be causing this? At this point I'm sure unsure whether it's a hardware of a software issue.
gpu: k2fa RTX 3070
Outputs I've tried:
HDMI
bluetooth
