I have 3 storage units namely ,
250 GB Samsung 860 Evo Internal SSD (newly bought) <---- C Drive
1TB WD BLACK CAVIAR Internal HDD @7200 RPM (+9 yrs old) <----- E/F Dive
500 GB WD Portable Elements External HDD @5400 RPM (+9 yrs old) <---- G Drive
Below is the pic of my +9 old 500gb WD Portable Element external hdd What do you make of the data ?
This one is +9 old internal hdd , What do you make of the data ?
Gets hot while transfering data
Gets detected @ startup but sometimes disappears in between task
Speed fluctuates a lot sometimes fast as 100 MB/s while sometimes even 0 bytes/s
Speed test on USB 2/Sata 2 @ 3 gb/s :-
SSD to HDD - 1 MB/s
SSD to Ext HDD - 1 MB/s
HDD to SSD - 100 MB/s (how ? y ?)
HDD to Ext HDD - 1 MB/s
Ext HDD to SSD - 1 MB/s
Ext HDD to HDD - 1 MB/s
Where,
SSD is 91% full
HDD is 80% full
Ext HDD is 5% full
- It always get stuck while normal formatting (quick format works fine) , any free software to fully format this ?
- Speed hovers in the range of 1-5 MB/s while cut/copy/paste on usb 2.0
- Drive actual capacity is 465 GB but can't move files after 315 GB leaving around 150 GB of empty space , any free cure/software for this ?
SSD to HDD - 1 MB/s
Where,
SSD is 91% full
HDD is 80% full
Ext HDD is 5% full
