Difficulty accessing Recovery console XP-Pro
robw
25
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello,
I have a machine running XP-Pro SP2.
It's not booting to the OS properly & I want run chkdsk from the
Recovery Console from an XP disk (slipstreamed SP2).
The problem is it's asking for "the" Administrator password. I don't
know it because I have another a/c with admin rights that I use
normally.
So far I have tried the following:
Trying a blank password
Changing pw manually with (net user administrator "password") from a
ERD console.
Astrumi 0.9.2 nt_pass util (including setting a blank password (*))
Should I run a chkdsk command from a NT boot disk & if so which one?
Extra info on what the PC is doing (or not doing).
It gets through POST ok.
It gets 30% though the "starting windows" (white bar on bottom of
screen) and just hangs there in the same spot every time.
If all else fails I will do a repair install.
Thanks,
Rob
Go to http://home.eunet.no/~pnordahl/ntpasswd/ and download the boot
disk, this will enable you to reset any system password on an NT class
operating system
On Fri, 16 Sep 2005 15:47:03 +1000, RobW <none@invalid.com> wrote:
>Hello,
>normally.
>ERD console.
I don't know about recovering the password for the admin account but if you
run chkdsk /r from a command prompt it should do the full check the next
time you reboot. It should ask you if you want to schedule a chkdsk...just
type Y and hit enter.
Scott
> normally.
Have you tried logging into that privileged acct and setting the
Administrator account's password from there?
Control Panel > Administrative Tools > Computer Management > Local Users
and Groups > Users > right click on Administrator > Set Password
On 15 Sep 2005 23:20:47 -0700, "GreenieLeBrun"
>operating system
Thanks, tried it but I still can't log in to recovery console
On Fri, 16 Sep 2005 02:47:14 -0400, Scott <scottm9000@hotmail.com>
>>Hello,
>>normally.
>>ERD console.
Plz re-read original post. You will see that I can't boot to windows.
The only command shell I can get is using a NT Boot CD.
Thanks.
> Thanks.
Thanks for clarifying.
The computer does not boot.
Thanks
