I have been facing a wired problem lately and its driving me crazy for a month. When I power on the machine the display comes at windows login screen (no bios info screen) or sometimes no display. This problem generally don't occur if I restart windows. But if I shut down the machine for a while and unplug the power cable for sometimes (20-30 mins) and again plug the cable and power on, the problem occurs.
Now the wired thing is, for troubleshooting I disassembled all the hardware from cabinet and setup everything outside of it, the display works fine (can see bios info also) every time. In this case I power on the system with a tester by shorting those power pins of motherboard.
FYI, I get a short beep every time after power on (even no display) and I checked gigabyte's site that a short beep means system normal.
I tried so far:
Please someone help me.
I tried so far:
- check the vga cable & monitor with other pc -OK
- cleaned ram & tried other ram slots of the motherboard -OK
- tested the smps with other pc for a week -OK
- reset CMOS and also changed battery -OK
- changed sata cable & sata slots.
