[SOLVED] Do i need a sound card to use the DT770 Pro with full performance?
encise
Commendable
Aug 21, 2018
115
Hello, here is my specs
RTX 2080TI FE
i7-8700K
32gb ram
H100I Cpu Cooler
Z390 Aorus Pro Motherboard
I'm willing to buy the DT770 Pro headphones, but my question is do I need a separate sound card or a mixer or something, like a sound blaster to use the headphones with all performance? or my z390 Aorus Pro Amplifier is enough?
D
There are 3 versions. The 32ohm model will run off anything. The 80ohm version are also relatively easy to drive. Your motherboard will do it easily. The 250ohm model will likely need at least a low power amp.
