Baskaran sampuranam
Hi, Good one to you.. Im Baskaran, in my system i have DVD Drive it working properly when i put the VCD where as if i put the DVD is not detecting in my system.. what would be the problem?
If it's reading a normal CD fine but not a DVD then just double-check to make sure you definitely do have a DVD-ROM drive. If you definitely do, then do you have the software installed to play-back DVD media? I would recommend VLC Media Player. Google it for more info. It's freeware and can play just about anything...a million times better than Windows Media Player. Good luck!
