[SOLVED] EZ debugger alternating between CPU and DRAM, does not POST.
Aug 3, 2020
Hey guys! I have gotten pretty much a new PC and the building currently does not POST, the lights ( LED Stripes and RAM RGB) are on and so are the fans. All the cables are all plugged in correctly and I have tried removing my GPU and using the default MoBo DP slot but nothing shows up on my monitor either. I have also tried using compressed air on my RAM and that did not help either.
The EZ Debug LED flashes onto the CPU LED for a third of a second or so and switches over to the DRAM Debug LED ( See: https://linkfileshare.com/0c7yU )
This building contains:
EVGA 600W B PSU
Corsair 220T RGB Case
2x 8GB RAM Corsair Vengeance
MSI Z390 A-Pro Motherboard
Intel i5-9400 CPU
MSI GeForce GTX 1060 (6G) GPU
250 GB Kingston SSD
2TB Samsung SSD
2TB Dell Hard Drive
https://linkfileshare.com/0yQx7
2x 27 Inch LED Monitors
Thank You all so much in advance!
Got it working (finally)! It may have been a short problem as my case is small. I put electrical tape around the areas where the case was touching the mobo and I think that may have fixed it
Reactions: rgd1101
