I've just updated upgraded my 1060 to a RX 6700 and its working out pretty well, obviously a big jump in performance.
Its this card: https://www.sapphiretech.com/en/consumer/radeon-rx-6700-10g-gddr6
I am noticing the louder fan noise though when the card is working hard. Plus the 6700 has 2 fans and my 1060 had 1.
I'd say once it hits about 1400rpm it starts getting noticeable (not sure if its purely the rpm, or if its a slight 'whine' at this speed), and it looks like its max is 1800rpm.
I was running it in New World on max settings and getting around 105-120 fps.
I've set it to a quiet profile here:
But should I customise it so that it cant hit 1600rpm, or is that risky?
I've not even looked into the undervolt/overclock side of things.
You can see the temps and wattage it hit here:
I've attached some logging from Adrenalin.
https://filebin.net/83nylolhvy9wza1b/20220820-004245-orig.CSV
Maybe I should just turn the game volume up!
