So I currently own a linksys e1200. I have disabled my firewall and wireless card, and I set up a static ip on my ethernet
adapter. Under the linksys settings, start to end ip address is 192.168.100-192.168.144; which I set my static ip to end
with 55 so that it is not under that range. I forward a port to my wired static ip, enabled it, but when I check to see if
port is open, it is not, and says timedout. What could I be doing wrong? I am trying to have a nat open status.
Also, if i directly connect my computer to the cable modem, would there be a problem of nat issue? Thanks!
