I've recently bought a prebuilt omen system (2nd hand) from a friend - Rtx 2060, i7 9700f etc. I benchmarked the system at his house, checked temps, everything seemed fine.
After a couple days at home the gpu would lose power anytime it would heat up enough to require power to cool it down via the fans, resulting in "no signal" on the monitor and a force restart being required.
I've seen this issue in threads all over the Internet and have tried every fix I can find: replacing thermal paste, trying different and older drivers, tested in 3 different pcs with PSU's ranging from 500w - 850w. Same issue every time. Do any kind strangers have any other ideas, or is the card just dead?
The system is (conveniently) just over a month out of its warranty. I understand the easiest option is to go back to the guy I bought it from and I have been in contact with him. However he is adamant that this problem did not exist when he used it (as you would be), and considering it's age I am inclined to believe him. Regardless, I'm stuck with it now so any help would be greatly appreciated!
