Question GPU running red hot on start up and there's no display ?
Mar 5, 2023
Hi!
Last night I was playing a game and as soon as I pressed a key on my keyboard both of my monitors black screened and my 3080 TI fans nearly took off.
I had to force a shut down! I then restarted my PC and my motherboard Q-LED for VGA is lit... and the GPU gets red hot instantly! I got my bros 1060 and I got back onto my system and I did a quick clean using Glary Utilities.
After about a couple mins my bros 1060 fans also ramped up to 100% and I lost my display again! My CPU doesn't have integrated graphics either.
MOBO ASUS PRIME X570
CPU: 5900X AMD
GPU: GIGABYTE 3080 Ti
PSU 850W
RAM 2 x 16GB TRIDENT Z ROYAL
Also my USB slots don't seem to work either sometimes! I was only playing LoL so I would expect my GPU would have been sitting at around 50-60°C
PSU 850W
850W is the advertised wattage of the unit. What is the make and model of your PSU and it's age? You might want to think about a 1000W PSU that's reliably built in order to power your entire build with an RTX3080Ti.
PSU 850W
Thank you for the reply!
It is a Corsair RM850 80 plus gold. It is 2 years old! My concern was that even though my bros card gave me a display and I was able to operate the machine... it didn't take long for that GPU to go max fan speed and my monitors going dark. Thankfully when I put it back in my bros rig it all fired up where as mine it won't on both cards
Really concerned about the temps when I put my 3080 back in as it just sky rockets but the fans maintain the idle speed and I still have no display! The VGA light Still on but the GPU is absolutely cooking within seconds as soon as the rig is powered.
