Question GPU usage is not maximum
Jaspreet_816
95
I have Ryzen 7 2700 stock cooler
16GB Ram (Single stick)
B450 motherboard
Zotac RTX 2060 (o.c to +175 on base and +600 on boost)
1600x900 (will upgrade to 1080p in near future)
When i play games like gta 5, battlefield V ,pubg or apex i see that frames are like 70-90 or even 100 in some cases but gpu usage is always nearly 50-60 percent Max GPU usage i see was 80 percent that was only for minute or so
CPU usage is also like 40-50 percent and when GPU percantage increaseds CPU percentage also increases.
I want to ask if is it normal or should GPU always work on high usage to get max frames
I watch some benchmarks in which like GPU usage is 98 percent and fps is max (eg above 100 in GTA V on ultra) whereas i get 50-60 or max 80 percent usage and get 80-90 or barely 100 frames.
Can anyone explain working of this system and how load on GPU and CPU Increases while gaming specifically.
One last question is if on 50 -60 percent usage i am getting 80 frames will the frames increase if gpu usage increases to 98 or 99
Thx in advance
Please also explain about cpu and gpu usage i am very curious to know.
I'm by no means any expert on this - but I'll assume 100% usage is almost impossible to reach - but it depends on how the measurement is made.
Say - if 100% must be understood as if all possible built-in draw functions in the GPU is used. That would be a far theoretical limit impossible to reach in any game.
Also consider this : Would any one drawing function (e.g. drawing circle) consume the same amount of resources if one is used or a thousand is in use at the same time?
For that I think someone in the GPU manufactor business have to answer - and even the question itselv is not certain to being valid.
