For the past month i have been having some serious problems with my computer. I use it for Blender, Unreal Engine, and Adobe programs.
Initially UE4 was crashing with a DXD error, which is my graphics card, (Geforce GTX 1060 6Gb) but then i started getting a lot of BSODs and other crashes. I took it to a computer firm, who ran stress tests on everything, and they said it was a faulty RAM module i had in. Took it out, and the crashes stopped, but UE4 still wont load. On top of this, Blender would crash on startup. Had similar issues in the past, and refreshing the OS sorted it, so tried that, but that kept failing as well, so figured i would do a format.
Before i did that, i ordered a new graphics card to try, an AMD 570 8Gb. Blender stopped crashing on startup, but the screen kept freezing, going black, then returning to normal, with the error saying display driver stopped working.
Did the format, and reinstalled windows 10. The black freezing error returned once AMD card was installed. Used DDU and put my Nvidia card back in. The black crashes stopped straight away, but now Blender, UE4 and Photoshop crash on start up. If i go into device manager and disable the Nvidia driver, Photoshop opens and works fine (apart from 3d settings). As soon as i enable to the driver again, it crashes the program straight away.
I've had 2 people look at it who cant say what the issue is. I really need this sorting as i am losing money while it isnt working, and would appreciate any advice you can give.
Specs:
Windows 10 64bit
Gigabyte B450m Ds3h motherboard
Ryzen 7 1800x CPU
32Gb Vengeance Corsair DDR4 Ram
Nvidia GTX 1060 6Gb Graphics card
600w Thermaltake TR2
240Gb Samsung M.2 SSd
1Tb sata Hd
Dual hdmi monitor set up
No overclocking on anything
Specs:
Windows 10 64bit
Ryzen 7 1800x CPU
1Tb sata Hd
