Hello all,
I was playing Apex Legends on my PC when all of a sudden my power cut out. I tried to reboot several times and my PC wouldn't turn on at all. I opened the case and smelled traces of a burn. I unplugged my PSU from everything and then tested it with each component to see what was messing it up. I found out that, when I plugged the PSU into only my case fan and then only my motherboard and then proceeded to turn on the PSU, the PSU was able to boot up and each component was able to run perfectly fine. However, when I plugged the PSU only into the graphics card, neither the PSU nor the graphics card would run. I rapidly pressed the power on button on the PSU (dumb idea probably) and then a little sputter of smoke came out of my graphics card. Is my card toast? Do I need a new card, or a new PSU? Help!
Also, I've been running this specific setup for 3 years. I'm running a GTX 970 and a 450 watt Dell PSU. I know that the 970 recommends 500 watts, but I haven't experienced any trouble until just now. Some help would be appreciated. Thank you!
Best wishes,
Ethan
Best wishes,
Ethan
