GTX 780 SLI - PC Appears to Short Out - PSU Amperage Problem?
Dacker
22
Hi. I'm having a problem with running two GTX 780s in SLI. Everything worked well for a few days but last night, in the middle of Fallout 4, my PC turned off and wouldn't turn back on - no power at all, even the fans wouldn't spin up.
After some testing, I unplugged the power cables to card #2 (in the lower slot), unplugged and replugged the power cable to the motherboard, and lo and behold my PC turns back on and I can game just fine - albeit with one graphics card.
If I plug the power cables to card #2 back in, the PC won't power on. When i hit the power button I hear a slight click, the fans nudge just a bit, and then nothing. Even after unplugging power to graphics card #2 I still can't power on the PC until I unplug and replug the motherboard's power cable.
I did a little research on PSU amperage. According to this link my graphics cards need 42A on a single +12V rail. According to the spec sheet for my PSU, the max output on the +12V rail is 83.3A. Does it sound like my two graphics cards added together are hitting the amperage ceiling of my PSU? If so, that's kind of a bummer since it was marketed as SLI compliant.
Oh, and whenever I plug card #2 into my other PC it works just fine and plays games as usual. Unfortunately, I can't test SLI in that PC because it's a mini-ITX and only has a 500W PSU.
Here's my PC:
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler
Motherboard: Asus Maximus VI Formula ATX LGA1150 Motherboard
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory
Storage: Samsung 840 Series 500GB 2.5" Solid State Drive
Storage: Hitachi Deskstar NAS 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card (2-Way SLI)
Case: Fractal Design Define R4 Blackout with Window ATX Mid Tower Case
Power Supply: EVGA SuperNOVA G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply
UPS: CyberPower 1500PFCLCD
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer
Operating System: Microsoft Windows 8.1 OEM 64-bit
Monitor: Yamakasi DS270 IPS SE 27.0" 2560x1440 60Hz Monitor
Keyboard: Cooler Master Storm QuickFire Ultimate Wired Gaming Keyboard
Headphones: Corsair VOID 7.1 Channel Headset
Generated by PCPartPicker 2017-04-09 21:55 EDT-0400
Sorry for the length of the post. I'd be very grateful if anyone could offer some advice or guidance.
According to here: http://outervision.com/power-supply-calculator
I've put your setup from your list, didn't include any usb devices though. I got 718 load wattage @ 55.8amps. Ups rating of 1300VA. You're well within power requirements for both psu and ups. 42amp 12v rail is for the whole system when they talk amps not just for the card.
Have you tried without the ups, it should be fine but just to be sure?
boju
Ambassador
Dacker
22
I wasn't aware of that power supply calculator site before - thanks! Turns out the prob was with one of the MSI graphics cards. I swapped card #2 out with another GTX 780 I had (an Asus) and I haven't had any problems since. The odd thing is that I put card #2 into the PC I got the Asus card from and have had no probs with it. Maybe it didn't like being card #2 and prefers to work alone.
