Question Guide for RTX 4070 Ti / 4080/ 4090
Gauravterna
35
I am planning to a build a PC ideally with a RTX 4080. However, I see some of the good rated cards ie Asus ROG Strix / MSI Suprim X are priced very near to cheaper 4090 Cards of Zotac, Gigabyte etc. Should one buy cheaper card of a better series or better card of a lower series ?
In case of the 4080, really not sure; if I should go for a EAGLE OC or Zotac AMP Airo and save around 15-20% on the Asus Strix.
Also, can the below link be considered a genuine grading for the GPUs ?
GPU Tier List 4080
Thanks in advance for your help.
GPU Tier List 4080
Unless there is not a widely reported problem with a specific card always get the cheaper model of the next tier. A Palit RTX 4090 will outperform an RTX 4080 ASUS Strix. Also if we speak about the same tier cards the ASUS STRIX will be maybe 2-3% faster than the cheaper models so i still wouldnt pay the price. Personally , for the same reason so far i only owned cheap models from Gigabyte , Palit , Gainward and never had a problem.
Thanks for the clarity...What would be suggest from the below ?
Zotac Extreme AMP Airo , GB Gaming , GB Eagle, MSI Trio X
That's really up to each individual.
Personal take: I sure as heck wouldn't buy Strix or similar, but I wouldn't buy the cheapest either. You get what you pay for, sometimes applies, sometimes it doesn't, and you land a gem for a bargain. It's not bloody consistent though, argh...
GPU Tier List 4080
I've seen thumbnails on my homepage, but have never viewed a single one... interesting.
I'd consider the grading flawed, as no single reviewer has tested every card per product tier. Even between Techpowerup and Kitguru, the testing conditions aren't the same, and that muddies things.
Thanks brother.. Can you suggest one from the below ? All these are betw 1300-1450 USD here..
Zotac is massively under rated brand
View: https://www.youtube.com/watch?v=4REHFWaWxzM
for 1099$ .There is no sense giving 200 or 300 more for some more famous brand
