[SOLVED] Hard drive not working after smoking pc.
Dec 26, 2019
11
Hi all,
Recently when putting in a new psu into my computer, my SATA cable started smoking when turning the pc on. I fixed this by replacing the SATA cable, but now I can’t boot my computer. It automatically opens to a screen that says map not found. When I fo into bios i put my hard drive as the first boot priority, but no luck. I’ve tried switching the SATA cable, ports and I even put the hard drive into another computer, in which it also couldn’t find a hard drive. Is the hard drive broken? Or did I overlook something, thanks in advance.
Oh - this is bad, with like capital "B" for bad.
The sata cable is not ment for carrying any current beside the small data transfer signal, and if such a cable is in a short circuit, it also means that the motherboard, the attached storage device (probably both) is fried beyond repair.
Hi all,
All electronics work on smoke, once it's gone it works no more.
Reactions: norcalsc
