Hey there!
**Any help is highly regarded.
Just got a new Gpu.
Worked completely fine for a few days.
Out of nowhere, screen would turn off and flicker, I would have green artifacts and all sorts of weirdness.. When this issue happens, screen, as ive said goes black for a few seconds, and when it turns on again all my desktop icons turn invisible (?) and are visible again if i hover my mouse pointer over them ?
No overheating. All parts in my case are new. Happened without overclock too. ( I had a slight one ).
Tried moving card to other pcie slot and havent experienced anything out of the ordinary, but the second slot is 16X (max 4x support). Only the first one supports 16X..
Edit: it's not the PCIe slot cos' same happened just now with the 2nd slot.
Specs:
ASUS Z390 Plus Gaming
Gigabyte RTX 2070 Windforce
Intel i7-8700
Gskill TridentZ 16GB RAM
Corsair 850W PLUS Gold
Windows is on M.2 NVMe
Just got a new Gpu.
Specs:
Intel i7-8700
