Question HDMI: "Input Not Supported" but VGA Works??
JudithWright
96
PC Specs:
CPU:
Intel Pentium Gold G6405 4.1GHz 4MB Desktop Processor
Motherboard: MSI B460M PRO-VDH WiFi ProSeries Motherboard (mATX, 10th Gen Intel Core, LGA 1200 Socket)
SSD: Lite-On 128GB Sata m.2 SSD
GPU: (optional): NVIDIA NVS 310
I am trying to install Windows on this system, but there is no display when I use HDMI (I have tried two different cables that were working fine before this).
There is a message on the Computer Monitor that say "Input Not Supported"
I tried installing NVIDIA NVS 310 graphics processor and used an DisplayPort to HDMI adapter but still no display.
I thought that might get around the issue, but that still didn't work.
The strange part is that I tried using a VGA cable - and that works normally. Monitor has a visible display.
Why would nothing work with an HDMI cable?
Can this be fixed?
PC Specs:
CPU:
Can this be fixed?
Display to HDMI 98% of the time won't work on install I don't know why but most of the time display port is deactivated during install from my experience if you have a HDMI port on the GPU id try that
