So I decided to try to open and solder my headphones after identifying the area of the problem, but when I opened the cable, it was not what I expected. I thought there would be 2-3 insulated copper wires and the solder would be easy, but when I opened them I found this (images attached), a copper wire, some white wool? and a black wire (the black wire is somewhat torn at the base and I think that's causing the issue because the rest of the cable looks fine). These are Sony WI-C300 wireless earphones. Any help or suggestions are appreciated! Thank you in advance
Image 1: https://drive.google.com/file/d/1L1Va82JcvBuLHGXU5Kau5iVRxs7MkTue/view?usp=drivesdk
Image 2:https://drive.google.com/file/d/1Ke2Hz140VxNt0EaZ0n10oKmzXeC8ItPO/view?usp=drivesdk
