Hi, good morning, I make this post because I can't do RAID 0 on my Aorus mother and I'm looking for help please
I really don't know what else to do ... I even updated the BIOS to the latest version ...
In BIOS, I go to "advanced configuration >>> configuration >>> IO ports >>> SATA and RST configuration"
I changed the option in Selection of SATA mode to "Intel RST Premium with Intel Optane" and below in the option "Control RST PCIe storage devices" Change from "Auto" to "Manual" and when I set the option to manual it appears below "PCIe Storage Dev On Port 9" and it appears in gray with the option of "Not controlled by RST" and it cannot be changed, I have 2 SSD connected to the M.2 ports and only one port appears, port 9 and the lo worse is that the port is blocked I cannot change the port settings and the second M.2 port does not appear directly .....
I leave the above configured like this and when I go to the "Intel Rapid Storage Technology" option, the "Create RAID volume" option does not appear, which should appear right there .... Help ... am I doing something wrong? Or did I miss something? Or maybe I am missing some component?
I have an intel i5 11400F and 2 SSD NVMe WD SN550 500gb ...
Sorry if it is not well understood, use google translate to translate this 🙁
