Hi,
I have a W10 PC running in the garage connected via ethernet as a backing up machine (BUPC) with RAID configured drive space, I run Iperius back up software on the main family machine and it has been working well doing weekly incremental backups of all our accounts. Recently I have received errors that the BUPC is not available on the network, something's gone awry I thought, and had a poke around. It appears I can connect to the machine with a remote desktop connection but when ever I try to access the public folder it tells me the network path doesn't exist. I have combed through all the obvious sharing menus on both sides and all is fine, I am at a loss.
This seemed to occur after I ran an AVG scan on BUPC and Bitdefender on my main PC recognised a port scan and blocked it, I'm wondering if a port has been blocked although I have tried using the IP of the BUPC in the exception list and even completely disabled the firewall but no luck.
Can anyone help?
Update: I can access the BUPC from other computers on the network but my main PC is not visible? Doing a port scan from the BUPC reveals one called BitDefender V1.0 or something, I have since completely uninstalled Bit defender from my main PC.
Can anyone help?
