[SOLVED] Help! Not getting display on my monitor!
nukesnicks
67
Hi, i just finished building my computer a little over an hour ago. It boots up well except for one problem. Graphics card wont display any signal... nor will the mobo. I tested my HDMI cables which work fine. Fits in the pcie slot like a glove and has full power. My concern is actually cpu power since my mobo has CPU power 1 and 2 and i only have it plugged into cpu power 1. Is that even a factor? IDK all very strange to me and still dont under stand the problem. Thanks in advance!
nukesnicks
67
Ryzen 7 1700x
GTX 770 Founders
T-Force Delta 2x4 (8gb)
MSI B450 Gaming Pro Carbon AC
600 Watt 80+ Bronze From EVGA (Dont know the exact model)
NZXT S340 Razer Edition
EVGA CLC 280mm AIO
Tell me if i left anything out :/
nukesnicks
67
Yeah 8 figured i should plug on the 8 pins. Skimming through the manual right now for the mobo. Im really not seing any results either.
nukesnicks
67
<mod edit>... only have 8 pin... is it needed or just for extreme ocing
nukesnicks
67
K thx
nukesnicks
67
Watched a video and said that 4 pin is not required (thank god) but i still need to find out ehy im not getting any signal. Could stand off screws have anything to do with it?
As long as the 8-pin CPU power connector is populated it should be OK for normal use. From what I've read the additional 4-pin is for overclocking, but that isn't specific to this motherboard.
If it boots up with just an 8-pin CPU power cable, that is probably the best evidence. But I would consider a higher watt power supply.
nukesnicks
67
Called nvidia and they recommended 600 watt power supply so odd that this is happening. Im really disappointed since i could have been able to play with this awesome toy today but alas i cannot
If you didn't install the motherboard standoffs, then definitely do that ASAP. Any thing that can short the motherboard to the case can be a problem with boot up.
nukesnicks
67
I mean i installed 4 mobo stand off and everything turns on... just no video :(((
This motherboard may require both CPU power cables to be connected to boot up. It may be that the system is booted up with no display, or it could simply be that the system isn't booted up. The 24-pin may be enough power for the LEDs and fans but not enough to power the CPU (without both CPU power cables).
nukesnicks
67
Ok im gonna see if its a monitor issue first then assume the worst. Thank you so much. Youve been a wonderful help to me today.
nukesnicks
67
Sadly dont have case speaker :/
nukesnicks
67
