NorthBridge is more for the CPU and Memory performance so increasing it wont help the GPU but just gives you higher clock on northbridge which is kind of pointless if your not ganna OC your memory/RAM... the built in GPU is more like a GPU you would normally buy but the different is that it's slower and cant do much games with it, OCing is pointless if your struggling with OCing it...
ifreestylin
991
Yes it can be
http://www.youtube.com/watch?v=HIk-juTFqjE
legendkiller
1,812
it's a built in with a CPU, you cant get much performance out of it... just do the same as he did with the GPU OC, shouldn't matter if you OC the CPU or not... It's a guide so you should be able to follow his lead...
ifreestylin
991
Ok thanks, just wanted to know if its the North Bride Voltage to change?
legendkiller
1,812
ifreestylin
991
Yeah i see that now am a just get a graphics card
