PC specs:
Context:
I used to have an AIO but it had a pump defect so until i got a new AIO i was using the stock AMD cooler. Today the new AIO came and so I was taking out the AMD cooler, however when i pulled the cooler it yanked the CPU out of its socket as well (while the lever was still locked down), and after a bit i managed to take the cpu off the Stock cpu cooler, and the pins didnt look bent or anything so i reinstalled the cpu back into the motherboard.
After installing the CPU cooler, as I was attempting to start the PC there was no signal being read by my monitors although the PC itself was on. So I thought maybe i installed the CPU cooler incorrectly and as i was tryng to take off the new CPU cooler it yanked the CPU off the motherboard AGAIN. Now I'm speculating if the CPU socket is now just loose and unable to make good contact with the CPU pins, or the CPU itself is broken.
But a lot of videos on youtube are suggesting a CMOS clear? Not sure exactly what it does so I'm gonna give that a try right now.
edit: did a cmos clear and it did nothing
- Ryzen 5600x
- Radeon RX 4700
- Asus B550 Motherboard
Context:
