Hi,
I'm not sure if this is the right forum. I'm not sure which one is?
I've read a large number of postings, reviews and articles on similar themes to this request and am basically suffering from what I believe is called PPA (Pre-Purchase Anxiety 🙂).
I want to build a fast games machine platform for a Nvidia 6800 GT. I'm considering all options but have highlighted two below for sake of discussion. I'm keen on buying very fast memory to try and get the best out of my system. I've read that games benefit more from a low latency than they do from a high bandwidth, so I've decided against DDR2 which all seems to be a CAS Latency of 4.
I'm looking for some help deciding whether to buy Athlon 64 or Intel. Generally speaking I prefer the idea of AMD with it's 64 bit processor and NX bit, also I'm suspicious of Intels approach with the XD bit. So despite my AMD preference I can't ignore what appear to be problems with running very fast memory with stability with Athlon 64's. As written up in the article on this website (http://www.tomshardware.com/motherboard/20040602/index.html).
The initial purpose of this system will be for playing Far Cry, Doom 3 and Half Life 2 at super smooth high resolution settings. I don't tend to care so much about all the Anisotropic settings I'm more interested in smoothness and resolution.
Here are two options, but I'm open to others:
Option1:
Intel P4 Northwood 3.4GHz Retail / Asus P4C800-E Deluxe / 1GB GeIL PC4000 Ultra Dual-Channel Kit - Bundle (BU-007-OK)
GeIL PC4000 Platinum is ready to take the full advantages of Intel's new chipsets to reach 250MHz+ FSB bandwidth!
- 184pin, Non-ECC, Un-buffered, high performance DDR memory modules
- GeIL 3.5ns 32x8 Density DDR Chip
- Optimized SPD for Intel 875/865 chipset Dual Channel DDR motherboards
- CAS 2.5 7-4-4 @ DDR500MHz PC4000
Price: £448.20 (£526.63 Including VAT at 17.5%)
http://www.overclockers.co.uk/acatalog/Intel_Bundles.html
Option2:
AMD Athlon 64 3500 Retail / Asus A8V Deluxe / 1GB Corsair XMS3200XLPT Dual Channel Kit - Bundle (BU-015-OK)
Guaranteed 100% Compatible Motherboard/CPU/Memory Bundles carefully selected by the Overclockers UK team to provide optimum performance and reliability.
A matched pair of 512MB XMS3200XL Extreme Low Latency (2-5-2-2) memory modules - 1GB total - ideal for dual DDR motherboards.
Corsair 1GB DDR XMS3200XLPT TwinX (2x512MB) CAS2 (MY-049-CS)
Asus A8V Deluxe (Socket 939) Wireless Edition Motherboard (MB-063-AS)
AMD Athlon 64 3500 (Socket 939) - Retail (CP-086-AM)
Price: £465.90 (£547.43 Including VAT at 17.5%)
http://www.overclockers.co.uk/acatalog/AMD_Bundles.html
So I guess I'm looking for opinions. Should I go with Athlon 64 and slower memory or Intel and faster memory with my ultimate goal being gaming performance?
Cheers,
Mark
Option1:
Option2:
Cheers,
Mark
