Archived from groups: rec.games.pinball (More info?)
Could somebody with a Williams parts catalog look up a T2 part number
for me please? I need the number of the metal ball trough edge/guide
that sits between the trough and the apron clip on the top of the
playfield. The ops manual does not show this part. Thanks!
Hi.I think the number you want is B-8623 called runway ball guide with
baffle.Bay Area Amusements have them for 6 dollars but are out of stock
at this time.You can put the number in the search box on their site and
it has a picture of the piece so you can make sure it is what you are
looking for.
>looking for.
Yes indeed, that looks like the part. Thanks VERY much for the part
number and pointer! Now to find one....
