G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I removed quicktime a while ago and it still was showing up in the programs
under start. So I went to the add/remove and it was still listed so I went to
uninstall and it said it was already removed. So it removed it from the list.
But the thing is it's still installed on the computer. I went to the
quicktime folder to see if there was a uninstall.exe but there isn't. I even
tried installing the same version and then uninstall but it doesn't work. I
can't find a unstall.exe. I even installed the new version which comes with
I-Tunes. The I-tunes showed up under the programs list under start but not
quicktime. How can I get rid of quicktime. I don't really need it. It's
really annoying me that it's still installed on the computer and I can't get
rid of it.
rid of it.
