Question Help! Right arrow key bound to two keys
Jan 3, 2020
4
My right arrow key when pressed acts like if I pressed it and the windows key too.
Earlier today, I was playing a game like always and I needed to press the right arrow, when I did this suddenly the window moved as if I clicked Windows key + Right arrow key, I also realized this because my keyboard lights up from the key that you pressed and when I press the right arrow, light comes out of both the right arrow and the windows key, I haven't been able to fix this all day
It's A Razer keyboard, the Cynosa Chroma to be exact.
It does have a software which is Razer Synapse 3, I checked on the app to see just in case if this was the case, and there was no success, since the keys were all default.
Try a clean boot and see if it changes anything - make sure to read instructions and make sure NOT to disable any microsoft services or windows won't load right - https://support.microsoft.com/en-au/help/929135/how-to-perform-a-clean-boot-in-windows
if clean boot fixes it, it shows its likely a startup program. You should, over a number of startups. restart the programs you stopped to isolate the one that is to blame.
It will also disable synapse but you can soon re enable it again.
alright, will try this and come back to you in a moment.
