Help with hyper x fury overclocking
jcsnyds
Commendable
Jan 1, 2017
System-
2x hyper x fury 4g ram 1600
Amd a8 7600 API
430 watt power supply
As rock
Cooler Master evo CPU cooler
Wd blue 1tb hard drive
This budget build was only 300 dollars and with the ram running at 1600 I can get 18-30fps on battlefield 1 medium settings which is playable for me.
But I do know that over clocking my ram will give me better performance, I have tried up to 2400 and succeeded only to have my PC crash while starting up the heaven benchmark to see if my score increased, then blue vertical lines showed up.
I would like to know how high you have gotten your ram to go and how you did it.
By the way I intend to get a dedicated graphics card in the future but I have a low budget and the apu gave me performance simpler to console
Plz help
jcsnyds
Commendable
Jan 1, 2017
Motherboard is a88m-g/3.1 idk bios but I have seen people on YouTube over clock this ram, mine is just unstable, should I increase the voltage from 1.6 to 1.65?
