Question Help with PC build component compatibility.
canning_s
100
Hi,
I am building a custom PC from a customize PC website and have customized a couple of parts. Can someone please have a quick look to see if these parts are all compatible?
Also, if there are any parts that are not recommended, do say.
CHACOR05010​
Corsair 5000D Airflow Black ATX MidTower Gaming Case Tempered Glass, CPU Cooler Supports Upto 170mm,...
VGAGBV44092​
Gigabyte GeForce RTX 4090 Gaming OC Graphics Card 24GB GDDR6X, PCIE 4.0 16384 CUDA, 3.5 Slot, 3XDP,... (for CHACOR05010)
CPUIT13900KF​
Intel Core i9 13900KF CPU 24 Core / 32 Thread - Max Turbo 5.8GHz - 36MB Cache - LGA 1700 Socket -... (for CHACOR05010)
WTRCOR9060058​
Corsair iCUE H100i RGB ELITE Liquid CPU Cooler 240mm Radiator, 2 X 120mm PWM Fans, Liquid CPU Cooler... (for CHACOR05010)
MEMGSK11524​
G.SKILL Ripjaws S5 32GB ( 2 X 16GB) DDR5 Desktop Memory DDR5 5200Mhz CL36, 1.2V, Black Desktop... (for CHACOR05010)
MBDGBM61522​
Gigabyte Z790 GAMING X AX ATX Motherboard For Intel 12th/13th Gen LGA1700, Z790 PCIe 5.0, 4XDDR5... (for CHACOR05010)
HDDSAM990100​
Samsung 990 Pro 1TB M.2 NVMe Internal SSD PCIe Gen 4 - Up to 7450MB/s Read - Up to 6900MB/s Write -... (for CHACOR05010)
HDDWD1929​
WD Blue Edition 2TB 3.5" Internal HDD SATA3 - 7200 RPM - For everyday computing (for CHACOR05010)
PSUGBM12900​
Gigabyte PG5 P1000GM 1000W Power Supply 80 Plus Gold - Fully Modular - High-quality native 16-pin... (for CHACOR05010)
OSYMSO3010​
Microsoft Windows 11 Home 64bit OEM Eng Intl 1PK DSP OEI DVD (for CHACOR05010)
ASSEMBGGPC​
PB Custom PC Hardware & OS Install for Online System Builder Only (for CHACOR05010)
Regards,
Simon
I would suggest these following changes:
PSU - get a better one. Gigabyte has not made a good psu yet. NZXT C 1000 from seasonic - https://www.pbtech.co.nz/product/PSUNZX1900/NZXT-C-Series-V2-1000W-Power-Supply-80-Plus-Gold
The GPU model is a baseline model from Gigabyte. Might as well go for a cheaper option - PNY XLR8 https://www.pbtech.co.nz/product/VGAPNY14093/PNY-GeForce-RTX-4090-XLR8-GAMING-Uprising-EPIC-X-R
The 13900K is a hot running chip. a 360mm rad for about the same price - https://www.pbtech.co.nz/product/WTRLAN1014/Lian-Li-Galahad-360-White-with-SL120-AiO-Water-Coo
There are some recent issues with pro series models from samsung, go for the cheaper evo models. 3500mbps is still good enough for most tasks unless you are a creator.
Frankly speaking, not a big fan of gigabyte. but thats just me.
Buy the ASRock Z790 LiveMixer ATX Form Factor For Intel 12th/13th GEN LGA1700... ( Z790 LiveMixer ) online - PBTech.co.nz
Buy the MSI PRO Z790-A WIFI DDR4 ATX Motherboard For Intel 12th/13th Gen,... ( PRO Z790-A WIFI DDR4 ) online - PBTech.co.nz
That Asrock board has some pretty weak VRM's for an unlocked 13 gen i9. Those cpu's are known power hogs.
