Question hey i need some help are my components compatible and are the any thing a can make better (trying to stay under 1500$)(gaming)
All compatible.
I suggest a better quality power supply to protect your investment. EVGA B2/B3 or G2/G3 lines would be more suitable. The B series is quite cheap.
CPU cooler is adequate, but you will want more if you intend to overclock.
All compatible.
should i get 650 or 750wat (evga 750 B3) or should i buy the 850wat (evga 850 b3)
All compatible.
for a budget like this you dont need to pay much you can go with this
Seasonic Focus Gold 650w fully modular for just 85$
BTW 550w is enough if you wanna go with thta version then its just 75$
