if you have a stock cooler that came with the CPU then all of the connectors are pretty much standard, the motherboard will have a fan connector (either 3 pin or 4 pin) and you simply connect the can to it.
the connectors are labeled and only connect in one way (unless you force something ) so you should be safe
other than that, I am not sure if you are asking about anything else.
