[SOLVED] How to connect rgb
Your board only supports RGB devices. You either need to work with an USB driven hub that accepts ARGB devices or swap the fans for RGB ones and pair it with a splitter that CoolerMaster(1 to 3 RGB splitter) make or a hub for RGB devices like this, mind you ARGB devices will not work with the latter two options.
