Hello, everyone. This is not so much a How to but it's where its best placed among the thread types.
TL;DR at the bottom.
So I have a PC with Windows 10 Pro (64bit) and a GTX 970 card, and recently got a LG smart TV. After that I bought a HDMI cable to connect them, and to my surprise, the graphics card only has 1 HDMI port, which is obviously being used by the monitor, so what I did was get an HDMI to Display Port adapter to connect it to the DP of the graphics card....but it didn't work.
I searched and searched and got no solution. I believe the GTX 970's DP doesn't work, or at least not with that type of connection (HDMI to DP), or at the very least, not mine specifically.
So after some more research I got some workaround solution to this. Use the DP on my MOBO.
"HOW TO":
So you go to the BIOS, then to settings, look for integrated graphics option, most likely it will be disabled, so activate it, then save and restart.
After restarting the PC if the driver of the integrated graphics is not automatically updated, then go to Device Manager, there should be a new item with a "?" and if you expand it there should be a display option with a yellow "!", double click on it and select update driver then choose to search for an update using internet (first option). After the download and installation process it's complete, you should see image signal in your TV.
Hope this helps someone, as it was a super pain to come about this trouble that shouldn't even be happening.
Special thanks if you read everything 💕
TL;DR: for some reason GTX 970 DP doesn't work, so activate the integrated graphics of your card through your BIOS, update its driver and use your MOBOS DP.
"HOW TO":
