TLDR: No Beep and No Video, most possible faulty parts are CPU, RAM, MOBO, PSU. Issue appeared after rearranging SSD and HDD SATA connectors, and reseating GPU.
Please read full description for entire story and details. Thank you very much.
I recently got an Acer Veriton M4620G, and a GTX 950, both seperately. I had an SSD laying around as well and decided to combine all these parts to create a decent gaming pc, for my usage it was enough. This PC worked flawlessly even through rough transportation and never had an issue, not even ONCE throughout the upgrade process. Not when I was swapping drives and installing windows, not when I added graphics card and downloaded drivers for everything and not when I would play for hours everyday and turn it on and off atleast 2 times a day.
Now I've been waiting for December break to upgrade it even further and get to enjoy more time with it. So on the first day I decided to upgrade it with more storage. 240 GB SSD was already in, so I added in a 500 GB HDD, in order to do this I had to take out the GPU to create space for me to work with the SATA cables. I took GPU out, HDD in, configured the HDD in windows while my CPU's integrated GPU handled video output into windows, and then I shut it off, reseated the GPU, and this is where the problems begin.
I pressed the power button, and as usual I expected the fans to make some noise, the hard drive to spin up, and the helpful SINGLE beep from the mobo speaker to tell me that everything in life is good. But that's not what happened. The cpu fan spun up for half a second, halted, then went full speed, which never happened before. And then, silence, no post successful beep.
When the beep is supposed to happen, it doesn't, and then all fans in the PC will be running at a relatively high speed, including the HDD disk. There will be no video or post or any signs of functionality for hours. I haven't tried running it in this strange zombie state for more than around a couple of hours, but in the end it only achieved to make my room hotter, there was no progress made. Also leaving it off and unplugged for overnight and then trying to turn it on gets me nowhere too.
I am not a complete newbie with PCs, so I did what I thought could help, and with some research I was able to isolate the following. (I may be wrong with these assumptions but it just doesn't seem likely that the following parts are causing the issues, from my case and from what I see others experiencing online)
Storage is OK
GPU is OK
CMOS battery ( I tried multiple different) is OK
CMOS Jumper was used multiple times, it is OK
This leaves the RAM, Mobo, CPU and PSU.
First off, It seems unlikely that the RAM just out of nowhere stopped working, especially since it was not malfunctioning prior to, or when the issue appeared. I was able to run this PC before with one of the two sticks, I tried both individually to make sure they work. But I have no way to check now that the issue is present, wether or not RAM is OK.
The motherboard COULD be bad, but I have no way of isolating it because I lack a spare set of PC parts or a different PC altogether to test the mobo with.
CPU could be dead, but like the RAM, it and the pins on the socket are in perfect condition, the thermal paste is properly applied aswell, and it was untouched prior to and during the appearance of the issue. I ordered a new cpu minutes before the issue arose so hopefully when that arrives I'll try to isolate CPU as an OK part.
Last but not least the PSU. I'm thinking the PSU isn't really the issue here, because it powers the fans (thru mobo pins), GPU, and HDD perfectly fine even when there is no post beep and no video. I can't be 100% sure however because I do not have another PC or set of parts to test it with.
Of these possible parts I can only really isolate the CPU when the new one arrives, but until then what can I do to fix this issue? I've waited so long for all this to be together and cleared my schedule to have some fun in my break, and now on the first day, for no reason, it just stops.
Literally any help is appreciated and I will respond as best as I can to any replies and will follow all suggestions. If there are any details or specifications you would like to have my provide I absolutely will. Thank you very much.
SPECS:
i3 2130
Ordered CPU: Xeon E3-1220 v2 ($10)
Zotac AMP GTX 950
B75H2-AM
8gb DDR3 1333
240 gb HP M700 SSD, 500gb Seagate Barracuda
Storage is OK
GPU is OK
SPECS:
i3 2130
Zotac AMP GTX 950
B75H2-AM
8gb DDR3 1333
