[SOLVED] How to know if a psu is going weak?
From past few months I have started to face a lot of issue with my pc.
It all started with my mouse led flickering when there is a power fluctuation.
From there it went to issue with UPS No. 1 (further referred as microtek) which I changed to APC but it exhibited more or less the same issue.
The issue was psu not responding quickly to the ups switching to battery backup from mains and vice versa. Some say its main capacitor holding time issue but system was not consuming full wattage of PSU so holdup time should be higher. Mind it same issue of shutdown on switchback to mains from battery was not seen when system was idle.
Another issue was the psu shutting down automatically when ups switched from battery to mains once the psu even shutdown when ups(apc) was supplying mains power through itself and pc was just on the desktop doing nothing.
Some said it was related to stepped Sinewave and apfc but if that was the case it shouldn't have worked with the UPS(microtek) for 10months or shouldn't have shutdown while ups(apc) was on mains mode.
So does this translate to a faulty psu or just my bad luck with UPS? As both ups exhibit more or less the same problem.
PC specs in signature.
If you need any more info please feel free to comment. I wrote this in a hurry so there maybe some grammatical mistakes.
It indeed does start again after shutting down by itself. After shutdown it pauses for 30secs or so and then starts up the system.
it could be your PSU then but it could aswell be something else either .
i don't know why tomshardware is obsessed with replacing psu's
But for instance last week i had some SATA power cables from my other psu connected to my current psu and the symptoms were the same.
So I have to change the psu to check it. What would you suggest?
CM Mwe Bronze v2 650, Seasonic S12II 620, Antec Ne600g, Antec neo eco bronze.
