because makes very noise soundsYou don't open it, you don't oil it.
Why do you think this is needed?
thanksYou would be better served by just replacing the fan. They are not designed to be oiled/lubricated by users.
they are two fans, duo , but one makes only noises 🤐🤐🤐And in any case, it's far more likely that the bearings become an issue, not the lubrication. And these are pretty cheap-looking fans.
Replace both.they are two fans, duo , but one makes only noises 🤐🤐🤐
guys thanks all , i will replace it, how to remove it ?![]()
not removed from cpu , i cant do it :XYou already did; one of the pictures clearly has you holding the fan removed from the heatsink.
