Dear forum members,
I picked up a MSI RTX 2080 Ti SeaHawk X. I installed the radiator on the top of my case, with push/pull configuration. On idle, the card is just 27 degrees (ambient: 20 degrees), which is good. As soon as I play a game, the card gets really hot. While playing The Witcher 3, it hits 75 degrees without any overclock. The radiator was really hot, the backplate was really hot, the tubes were hot, and my fans were already spinning quite fast. The pump was also really really loud, like annoyingly/disturbingly loud. The cpu was really cool (around 55 degrees with a overclock on), and I have good airflow in my case (1 200mm intake on the front, a 140mm intake on the bottom, a 140mm exhaust fan, and 2 gpu radiator 120mm fans).
I am quite lost. A hybrid card should be cool and quiet right?
Should I apply new thermal paste? Does that help, as the radiator does get really hot, so there is a big amount of heat transfer? But I have read that MSI's thermal paste application isn't the greatest, so might be worth it right?
I hope you can help me!
System specs:
Ryzen 2700x @ 4.2 ghz
Asus Crosshair Hero VI
Crucial Ballistix Sport 32 gb @ 3200mhz
Be Quiet! Dark Power Pro 750 watt
Phanteks Enthoo Luxe
System specs:
