Question I need help!
Dec 30, 2021
I need help!
Hey I would like some help, the error LED’s on my mobo keep cycling
Specs:
Mobo-Aourus b450 pro Wi-Fi
CPU-R7 2700x
CPU Cooler-Stock
Gpu-xfx 5700xt Raw II
Ram-32gb (2x16) Corsair Vengeance RGB Pro SL 3600MHz
Case-Thermaltake V200 RGB
I was over at afriends with my pc and when I was going home my pc fell over (from standing up to on its side) and now the error led’s will cycle one after the other, first the CPU led will turn on and off for not too long, the the Ram led will be on for a few seconds, then it goes to the VGA led for a few seconds, then it will go to the boot led for not too long, then no led’s will be on for a few seconds but then the cpu led comes back on and it repeats, I’ve tried switching out the ram with my old ram that worked in it before Christmas, I’ve removed the gpu and tried it, I’ve taken the cpu fan off and took out and put back in the cpu, cleaned it off and put new thermal paste, it had no bent pins, I tried 1 ram stick at a time, all the same error, I have no idea what’s wrong. I have also tried a cmos reset, I’ve unplugged all components and called from my mobo except cpu at the same time then put them back in and tried it, I’ve also tried different ram and a different gpu, got the same result except after I switched the gpu it would do the cycle once and not repeat but still no output.
I need help!
Specs:
CPU-R7 2700x
CPU Cooler-Stock
May be cracked MB ?
