Hey guys,
I am currently in the process of upgrading my PC build and have few upgrade options to choose from and would like your opinion on it.
My current PC build is:
i7 6700 cpu Skylake
GTX 1070 Asus Strix graphics card OC edition
MSI Z170a M7 motherboard
16GB DDR4 RAM (8GB x2) 3000MHz G.Skill TridentZ RGB + Old Corsair 8GB RAM Stick = Total 24GB RAM
1 TB NVMe SSD WD Blue SN550 Gen3 x4 PCIe
2x 27" Monitors @ 60Hz (one is TN Benq Panel and other is IPS LG Panel)
Option 1:-
Get the RTX 3080 MSI Gaming Z Trio/ASUS ROG Strix + Z690 MSI Edge WIFI (DDR4 supported to use my old RAMs) + i7 12700k CPU
while keeping my old monitor @60Hz in the meantime and upgrading it in the future to a 27" 1440p 144Hz G-Sync HDR10 Monitor
Option 2:-
Same as previous option but get RTX 3070 instead of 3080 and use the extra money to get a 1440p 144Hz G-Sync Monitor
Option 3:-
Get RTX 3080 + Monitor upgrade 1440p 144Hz G-Sync Monitor while keeping my old CPU/MOBO combo and upgrading it in the near future
I know this may be the less ideal option as i will experience bottleneck in some games due to limitation of my old CPU, but it will still give me better fps than my old GPU at least thats what I reckon
Prices of GPUs mentioned where I live is
RTX 3080 ~= $1,820
RTX 3070 ~= $1,277
TLDR; I cant upgrade all three at same time; (i7 12700K + Z690 MOBO) , RTX 3080/3070 , 2K/1440P 1440Hz G-Sync HDR10 Monitor
I wanna get 2 out of the 3 upgrade options now and get the last upgrade sometime in the near future
Let me know your opinions and why,
Thanks in advance
i7 6700 cpu Skylake
Option 1:-
Option 2:-
Option 3:-
RTX 3080 ~= $1,820
RTX 3070 ~= $1,277
Thanks in advance
