Hi guys, I have a problem here
I bought from the internet an IP camera, which also has built-in WI-FI, and I can connect to another router with 2.4 ghz, and the camera is online, I can access it from the phone.
Okay, now let me tell you what I want to do.
This camera has ip 192.168.100.100 and the WIFI router of the camera has 192.168.100.1
The main router I connect to is 192.168.0.1
DVR is 192.168.0.100
I activated uPnP, and I did port forwarding (maybe i did something wrong here)
At DMZ I didn't touch anything, it's off.
The outcome? If I connect to the router of the camera, I can access the ip of the main router, and I can also access the ip of the dvr. Conversely it doesn't work, more precisely if I only connect to the main router's network, I can't access the camera router, but I can access the camera. In DVR I can not find the IP camera, even if I put it manually, it is not detected.
In this sense, the connection goes.
CameraIP + WIFI-> main network-> DVR
The opposite doesn't work.
A tip, advice, something, help please
