The voltage you are showing is fine....Anything under 1.35v is usually good with 1.35v being Intels max safe for your CPU though you can go all the way to 1.4v which I would never do....but Auto always tends to feed a bit more vcore than required but you are well within specs and temps look good as well.
If you want you can try to lower the vcore and see if you are stable....but bottom line you are good to go as is..
