Check out the reddit post i made for this. Thanks!
View: https://www.reddit.com/r/overclocking/comments/kwec9m/is_my_cpu_fit_voltage_right/
Based on the HWInfo readout for CPU Vcore (SVI2 TFN) I'd say your FIT voltage is closer to 1.237V. That's the MINIMUM reading which is the point to which the algorithm has lowered voltage in order to protect the CPU, which is what FIT is all about.Check out the reddit post i made for this. Thanks!
