Hey guys.
Recently i bought a new RAM/CPU/MOBO
Ryzen 3 3200g
HyperX Fury 8gb ddr4 3200mhz cl16
MSI A320M PRO V2-M2
(The GPU remain the same, MSI Radeon RX 570 GAMING 4GB OC)
After I put everything together, everything started running up as it should be(based on sounds) and i kept getting black screen with NO SIGNAL and the EZ DEBUG LED was lit (CPU)
The things I've done so far, Cleaning the tips of the cables, taking the cpu in and out, switching the little battery, switching the ram in slots, taking the ram out/taking the gpu out.
I also kept getting the CPU light even after i removed it with everything else so it might be a faulty Mobo? who knows, i cleary dont:s
It worth mention that the box says it only supports Ryzen 1st&2nd gen, and on the MSI website it says it should be good to go(https://www.msi.com/Motherboard/support/A320M-PRO-M2-V2#down-bios )
I couldn't find anything helpfull on the internet about this issue so far, but i've found benchmark videos using the exact mobo with a ryzen 3 2200g/3200g so its another point that it should be compatible.
Thanks in advance for the replys!
Ryzen 3 3200g
MSI A320M PRO V2-M2
