Is there a software I can use to help with rgb controls?
Feb 28, 2019
Is there a software of some kind that lets you add effects to an RGB keyboard that doesn't have many effects? Can i program it to use corsairs software or anything?
Unless your keyboard brand doesn't have its own software then probably not. The razer keyboards on amazon are good/cheap with its own software and a ton of different rgb options.
