So, about a week ago, I unhooked everything from my PC (Besides CPU/Heatsink and RAM) and aired out the GPU, Radiator, Fans, PSU, and Case with the compressed air tank we got in our garage. (Was just doing some cleaning because it was very dusty in the places I can't normally reach)
Plugged everything back in, when I hit the power button it didn't work but then it did like 10 minutes later.
Lights on the Motherboard and GPU were on, but the Case nor Motherboard power button did anything.
Lights are on but no one is home moment.
Since the PC was working finally, I just assumed the power needed to cycle or something.
Last night before I shut the PC off, I hear a beep through my headset. I've never heard it beep before in this exact situation. Just a single beep through the headset, nothing that sounded like a BIOS code.
(Every night I have the PC turn itself off through a custom command line because I like to listen to stuff as I lay down to help me relax, and then let the PC just turn itself off after 20 minutes)
Went to turn the PC on today and nothing, another lights are on no one is home moment. Took everything out (again, besides CPU/Heatsink and RAM), every cable was checked but I didn't see any damage. I even replaced the CR2032 battery, mine was apparently dead but I did not get any BIOS beeps prior. Sprayed CRC electronics cleaner in the cables and the Mobo connections then let it dry and re-hooked everything. Nothing.
Even with the GPU out, and one RAM stick in. I decided to swap the RAM stick to the other channel, and magically it turned on. I turn the PC off, plug everything back in, and it won't turn on again.
I mess around with all the cables, reseat the ram twice and make sure everything is reconnected once more, and it powers on again. Currently running fine and the BIOS settings I believe were reset to default.
Is this a sign my PSU is dying?
Motherboard: ASUS Hero VII
PSU: Corsair RM750
GPU: Asus Strix 980TI
RAM: 2x 8GB Corsair Vengeance DDR3 1333hz
PSU: Corsair RM750
