Hello,
So, now that ive done my best to help others, im having an issue. I recently moved, and when i did so, took very good care of my computer (especially the tower). When i set up the computer system after i moved everything in, i turned it on, hooked up the speakers (through USB port because something happened to my motherboard ports a long time ago) and, in the same settup configuration as before, started playing music. In the first 10-15 seconds i noticed a small stutter in the music. I moved the files from the external drive to the internal drive thinking, maybe something happened and the external isnt working properly. That didnt help. I reinstalled the drivers for the motherboard (full complete driver set, USB, Audio, BIOS, everything). And that didnt help. I have run scans with Ccleaner, Spyware Doctor, Lavasofts- Ad-Aware. and nothing. Fixed a couple of things in the registry with Ccleaner, but did not solve my issue. I ran a sfc/scannow, and it found no errors. I ran a chkdsk, and nothing. Im am royally stumped. What do you guys think my next step should be? (i will only resort to a reformat if that is my last and final option.)
Thanks for any ideas (even if they are only guesses, ill try anything short of downloading a file i dont trust)
~Trey
~Trey
