Keyboard problem - help
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
my keyboard is not working properly. The "." keeps becoming a ">" and the
caps lock looks like it is on but it isn't. The numbers are also showing the
symbols as if the caps lock is on. I have tried a USB keyboard and this
gives the same problems.
I have also reinstalled XP (home eddition) but the problem has come back...
is this a virus or is it a setting problem? help!!!! web browsing is
almost impossible and it comes and goes..
thanks
Replace your damaged or defective keyboard....
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
| thanks
I have been talking to dell and they say it is not the keyboard as it is a
brand new laptop and a USB keyboard does the same thing when it is attached
so they say it is software
> Carey Frisch
> Microsoft MVP
> | thanks
The problem described in the original post is most certainly NOT the
keyboard. I had the same thing happen to me on my HP a few weeks ago,
and also the mouse no longer worked as it used to - I couldn't select
just one icon it highlighed many at one time, could not select a
portion of text, etc.
It seems like someone responded to my post on this problem (or maybe
no one did) that it had to do with the accessibility wizard. Never
could find anything abut it there.
Well...it just happened to me again and the cause was clearly some
strange combination of keystrokes I did not intend. My only fix was
to do a system restore back to yesterday. But it sure would be nice
to know how to undo this problem.
Vicki...I assume you got it fixed (without buying a new keyboard) and
I'm curious how, in case it happens to me again.
Jim
On Mon, 1 Aug 2005 20:32:17 -0500, "Carey Frisch [MVP]"
the
showing the
this
back...
thanks
Jim
the
showing the
this
back...
thanks
How about toggle keys.
http://webdiary.smh.com.au/archives/_comment/001075.html
"Jim" <nospamjak@comcast.net> wrote in message news:tpfhh19duneat9h71a5lr19urua1fi7d4p@4ax.com...
> Jim
> the
> showing the
> this
> back...
> thanks
Found that in accessibility but it does not create the same symptoms
in either setting..
That system restore fixed the problem both times, not to mention the
mouse problem tells me it's not a keyboard problem.
I guess Vicki and I just have a unique problem that no one on this
forum has ever seen. Perhaps it's a bug in XP that only the 2 of us
have managed accidentally invoke.
Though usually it's dirt in the shift key.
> Jim
> the
> showing the
> this
> back...
> thanks
And that screws up the mouse?
Yes, as ctrl + click is multi select and shift + Click is select all between click and shift + click
"Jim" <nospamjak@comcast.net> wrote in message news:uvqhh1p7q47pt5crik3e2mo7pt8rg95g4v@4ax.com...
Thanks much. I do see that if hold the shift key down all the time I
can replicate this problem, I think. Will just look at the shift keys
and ctrl key next time. I now see the shift key does sometimes stick
down.
Still wonder why system restore fixed it both times. Maybe that
ejects the shift key :-o)
There was a similar problem is Win 95 or 98 that had a wierd cause that I can't remember. Not dirt or toggle keys. I just can't remember but it was an obscure and not logical cause.
"Jim" <nospamjak@comcast.net> wrote in message news:l3rhh1pe8ev4l6p1guhdq1fgq1rjhfn4ms@4ax.com...
> in either setting..
